Had an issue need help
MustangJunkie
Had an issue on the way back from mustangweek last night. The car drove fine all the way back untill got near the house pulled up to a stop sign and car just died but cranked right back up with no problem drove 10-15 more mile to another stop sign and did it again. it dont seem to run bad or nuttin just shut off when i came to a stop. Please help!!! :BangHead: :BangHead:
MustangJunkie
happened again today drove it about 20 mins down the road came to a stop sign and bam it shut off but this time it reset the radio like the car lost electric power. so i pulled the codes and 2 codes had something to do with the o2 and one code was egr. this is the same three codes ive gottin ever sense ive got the car my guess was cause of no cats please help gettin kinda scared to really trust it now
SlvrBullet98
might suggest checking ur battery connections (easy enough). and if the egr was stuck open it could definatly cause stalling issues (remove the egr valve and see if its all gummed up and stuck open with carbon). could also be an iac. but if u have egr codes id start there
MustangJunkie
When it shut off today i had advance auto parts check the battery and charging and they said that it was all fine. thinking it may be with the o2 sensor, i had a 88 gt before and o2's went bad and was sending ground back thru the acc. wire and finally wouldnt let the car do any thing cause i replaced the starter, starter soliniod, batt.,and alt. till i finally traced the acc. wire down to the o2's unplugged them and it fired rite up and never had the issue again.
MustangJunkie
VooDoo95Cobra said:
i know i have a 5.0 but i was having the same problems and i replaced the iac and its been fine ever since..
but shouldn,t it show so kind of code
MustangJunkie
I think i have found my issue I took all 4 o2's out and the back 2 both had wires burnt into and the ground was a lil loose so i changed the end on it and fixed the wires on the o2's so now i just gotta drive it and c.
