hanging idle ( again )
stocker95
Hi gang , got a 95 gt 5.0 5 speed that is idling at around 1800 , the IAC seams to be working but when unplugged with the car running there is no change in idle . replaced the TPS with no change . checked for vacuum leaks .. none . car is bone stock. tired of chasing my tail lol
evilcw311
Most Evil Member!
Louisville, KY
If you are sure that there is no vacuum leaks then it’s more than likely the iac. If nothing changed after unplugging it then it sounds stuck.
Take it off and see if it’s all honked up and if the spring moves freely. Mine did the same, cleaned it up really good with carb cleaner and then put a couple drops of oil in and worked it back and fourth. Problem solved.
Be weary of autozone iac’s. Bought s new one before servicing my old one and it made it worse.
stocker95
pulled it off , looked fairly clean . " tested " it by bumping it with a battery . but didn't like the fact that nothing changed when I unplugged it
stocker95
Is that how you test an IAC? the IAC is a pulse width modulated motor is why I ask.
going to say it is not the correct way to check it , but it clicked when I did it lol . fixing to go out and mess with it again in a few
evilcw311
Most Evil Member!
Louisville, KY
Try what I said to do and see if it helps. The fact that it doesn’t change idle when you unplugged it really keeps my thinking it’s that.
stocker95
pulled it again , not really that dirty , cleaned it again and hit it with some oil , still no change . also still no change when I unplug it
01yellercobra
If it's hanging at 1800rpm then you have a leak somewhere. And it's after the throttlebody since unplugging the IAC didn't change anything. For it to be hanging at 1800 means it's a decent sized leak. I'm assuming the 5.0's have Evap stuff. You might have to check those hoses as well.
FWIW, a buddy of mine kept chasing a high idle in his 03. I kept telling him there's a leak somewhere. He changed gaskets and throttle bodies and added return springs. Finally he started poking around and found an elbow under the blower was leaking bad. He could feel it. But he couldn't hear it. Replaced that elbow and it idles great.
Sent from my SAMSUNG-SM-G935A using Tapatalk
how did you check for vac leaks? Smoke test? If not do a search on youtube and they show some easy diy ways to do it.
