harmonic balancer help?
95marcos
Guest
well the harmonic cause a lot vibration when u step on the gas i was trying to set my timing but it seems like its not the right timing car runs poor any advice?
topless95
you can always set the number one piston to top dead center on the compression stroke and see if the balancer marks line up
95marcos
Guest
when taking off the bolt from the crank is there anything i should be careful about?
Paul
Check the threads at the bottom of this thread in "related topics" and you'll get what you need.
yea, the HB prob spun. i noticed mine was after i R&R'd the dizzy. car ran good but the timing was way off, then i noticed the wobble in the HB. so it got swapped too. that bolt on the HB is f'n tight. hopefully you have a 1/2" impact. i didn't so i used a huge pair of channel locks to hold the old HB and a 3' breaker bar on the bolt. DON'T PUT ANYTHING ON THE PULLEYS, that'll screw them up.
GearGambler
Northeast PA
if you need a new one, shoot a PM to artie (arts performance parts) he's a vendor here. got mine from him for a good price. professional products i believe. great replacement SFI balancer.
Dr Fildo
Jersey
The thing that got me when I replaced mine is that there is a washer on there, between the nut and the block - When I removed the nut, the washer stayed in place, and I put the puller on it (a novice mistake, but whaddaya gonna do?) - after 2 days of cursing and breaking one of the bolts on the puller I borrowed from AutoZone, I stuck my finger in there and pulled out the washer. I was finished with the job in 20 minutes after that. And the nut was on there TIGHT - if you have access to an impact wrench...well it saved me a lot of effort.
95marcos
Guest
yea the harmonic balancer was bad i changed it today and the vibration went away completely i tried to set the timing right but there is just something not right it runs really sluggish driveing me crazy i think should have just left it stock it ran soo much better
did you put the spout back in? not trying to be smart, just making sure. was that the only thing you changed?
Spend the money and get some ford racing SFI balancer or Pioneer balancer. It is worth it and you sleep better at night.
95marcos
Guest
yea i put the spout back in its weird cuz when i got the car it was bone stock and ran a hell of alot better the only time i noticed the change was when i changed the fuel pump to 155lph but only lasted a little bit im just thinking about taking it to a shop
Paul
When the balancer died on my '95 GT daily driver - I got a stock replacement from Ford for $69. Works like a champ.
If you don't have the tools or know-how to do it, this is a great job for a shop. They'll usually only charge you an hour labor, and they can zip it on/off in no time.
Paul.
95marcos
Guest
i got a harmonic balancer from advance a pioneer... i already installed it and it took away the vibration away its just that i cant figure out way it runs so poorly its like if the timing was still off
