Head gasket mistake??
1994stangfan
Ontario canada
I just realized that I ordered Fel Pro mls gaskets number 1134 which is 4.180 bore my engine is not bored at all. Stock gasket is 4.100 I believe. What shoukd I do now?
evilcw311
Most Evil Member!
Louisville, KY
Best answer is tear your motor down and bore it to match. Can never have too much displacement.
Boring answer is see if you can return them and get the correct ones.
castine917
wyoming, mi
Either put gasket on which will only be a minuscule compression difference or wait for exchange. I would install and not think about again.
96blak54
Staff member
Lawrenceburg Kentucky
Should be fine. Performance aspects are the factors with this, but only if the engine is set up for it.
Could chamfer the cylinders to the gasket bore size. Doing so improves valve unshrouding
1994stangfan
1994stangfan
Ontario canada
Thanks for all of the replies. I will see if I can exchange them if not I will go ahead and install them.
1994stangfan
1994stangfan
Ontario canada
Can you elaborate on “performance aspects†I’m not sure what you mean
96blak54
Staff member
Such as high compression. Un spent Fuel being trapt between the head and block. Who knows, you may stumble onto something good. Goofy things like this happen all the time and magically perform better...who knows why. I dont see using the gaskets would pose a big problem on an otherwise stock engine
