Head install question(related to cam)
BruhBrahBrad
Ok quick run down, my car has stock heads and intake, but a aftermarket cam... In theory shouldnt I be safe with installing gt40p heads? I shouldnt have any issues, if I didnt have any with the E7s right?
Win
Kennesaw, Ga
You technically probably will be fine but STILL CHECK PTV. While you have everything apart go ahead and upgrade the RR's and do the springs if you have the money.
B
BruhBrahBrad
I should crack my valve covers to see if any of that stuffs been changed but I dont wanna waste a valve cover gasket just yet.
Win
Kennesaw, Ga
That's the cheapest i have found it with the Free Shipping.
if you can swing it snag up the TFS Spring kit for iron heads, and some 1.6RR or some Crane Cobra 1.7RR just make sure to check the PTV
Win
Kennesaw, Ga
LMR
This is all i left to buy. Although this will take care of you and you'll be set.
ARP-1543601 79-95 MUSTANG 5.0L ARP HIGH PERFORMANCE SERIES HEX HEAD BOLT KIT
$ 44.99
M6003A50 79-95 MUSTANG 5.0L/5.8L COMPLETE ENGINE GASKET SET, M-6003-A50
$ 79.99
TFS-2500100 79-95 MUSTANG 5.0L/5.8L TRICK FLOW VALVE SPRING UPGRADE KIT FOR OE STYLE CAST IRON HEADS
$ 149.99
Order Total: $ 274.97
