Header Gasket
CanaryGT
Phoenix
So I put on a Stainless Steel Engine Kit When I did my engine. I used new Header Bolts, but they use hex instead of a standard bolt. Does anyone know of a tool to get them out easy or am I stuck in there with a 90 degree hex wrench one slow ass turn at a time.
CanaryGT said:
So I put on a Stainless Steel Engine Kit When I did my engine. I used new Header Bolts, but they use hex instead of a standard bolt. Does anyone know of a tool to get them out easy or am I stuck in there with a 90 degree hex wrench one slow a*s turn at a time.
hit up harbor freight. For my valve covers they had hex-head and i had to use a whole array of wacky ass stuff to get to them.
my biggest asset: the allen wrench kit that folds up into a handle.
like these:
<img src="http://www.ted-kyte.com/3D/Pictures/Allen Wrench Set.jpg">
undo the bolts, and take the wrench out that you need... then you have an "eye" on the end. you can put a screw driver (or another wrench through it) for leverage, and its small enough for the tight spots.
another thing i used was the allen wrenches with the ball-tip, so you can use them at an angle.
like these mo fos:
<img src="http://img.directindustry.com/images_di/photo-g/ball-end-allen-key-353808.jpg">
and finally a set of these bad boys:
<img src="http://rocky.digikey.com/weblib/Wiha/Web Photos/mfg71392.jpg">
i had to use all of those, along with the regular 90* L-shapped allen wrenches to get my vlave covers on and off.
wytstang
The first one pictured above would be the fastest way to get them out. Your patience will be tested lol.
CanaryGT
CanaryGT
Phoenix
I have the last ones pictured. They are too big next to my headers to get a fit.
The Middle ones are super expensive around here. Ill have to look around...
that is not a cheap name, but as he said harbor freight has them as well just make sure you buy an extra, maybe two.....
also if you notice those have the long end with a ball-end. That will allow you to use it at an angle other then 90 degrees from the bolt but can also help strip it if it is too tight.
TxCobrA98
the ball-tipped allen wrenches are awesome, i have a set of metrics and standards
also, hit up Harbor Freight like everyone said or Northern Tool, they have great deals on tools
96GTPlanB
