Headlamp swape out..
bens95svt
Bought some smoked headlamps and corners with foglights and was wondering if someone could point me in the right direction for instructions on how to change them out...Never messed with headlamps changed bulbs but not complete light housing...
Thanks
95 svt cobra
there is 2-3 bolts per lamp and one bolt for the corner lamp, just undo the nuts on the back of them and they will pull out. Installation is the reverse, + then adjusting the headlights so they are even/projecting on the roadway
kyle94gt
im not exactly sure how many there are but I know that on each headlamp housing, where the adjustment screws go through the core support, there are one or two clips that just slide out on each side. They will look like a bent piece of metal. Pull straight up on them and they should come out. then there should be one or 2 nuts the hold the side marker on take them off and they pull out. Installation is reverse. hold your old housing up to your new one and adjust the screws to a roundabout even spot and put them back in. Pull it up to a piece of plywood or a wall so you can aim them correctly. Good luck!
B
bens95svt
THX give it a try when the freaken rain stops here...but we do need it though :p
