Heads, intake and the computer
BackinBlack
What kind of luck have you guys had with head and intake swaps? How forgiving is the computer? I know a cam is going to require some dyno time but I'm trying to aviod that right now.
95-stang
So far i've ditched the cats, removed the smog-pump and fitted a Ford Motorsport intake with 65mm throttle body and no problems.
So i would be interested too, as my next job will be heads. :)
B
BackinBlack
My mods include LT headers, o/r h-pipe, c/a intake, 70mm tb, adjustable fuel pressure regulator (set to 40 psi), 24lbs injectors, tuned and ported maf, underdrives, 180 thermostat, MSD 6A, coil, cap and rotor, and FRPP wires. It all works pretty well together except it runs a little rich on th low end. I just don't want to lose driveability or have the light come on.
Slow94
I just uilt a 331 for my 94 and it runs pretty good with no tune. I'm still getting one though. From what I have seen it's hard to say what someones car will do with mods. I have seen 2 cars with the same mods act way different, so it seems like the computers have a mind of there own,LOL
Paul
Why on earth would you go to all the expense of a heads/intake swap and not get it tuned?
B
BackinBlack
What cam are you running?
B
BackinBlack
Mine probly isn't going to be happy without a tune. It acted up when I tried to bump the timing just 2 degrees. A cam would probly make it freak out.
Suspect
ATL
i think its a hit or miss. it seems some cars need it right away, some dont. ive read a few people ride for a year or 2 before getting tuned.
i have an ecam and tf intake and never had a problem. now i have heads ready to go in and also ill be swapping to a tf stage 1 cam. hopefully mine can last a few months until i get it tuned. if it acts up right away then ill get it done asap. well see. :)
I just finished my head/cam install, went with AFR 165s and Steeda #19 cam, after playing with the timing and idle a little the thing is running great. Idles around 800 with no problems. I still want to get it tuned but it runs really good as is.
SaleenStang94
after a motor swap here, my car ran like ass. very slow, dumping fuel, everything wrong. had to get it tuned bad. after the tune and chip it ran much better.
rjac
