heat coming from center console??
kraz3y
Jus recently i've been feeling alot of heat coming from my feet...its seems to be radiating from my center console i think...? what could it be?? :help2:
95-stang
How hots the transmission thats under that floor area?
Mine does'nt get that hot, but then i live in a cool part of the planet. ;)
Twista
I get that too.. it happens when i drive the car hard for along time. I mean its obvious on a 5/6speed because your hand is always by the tranny so i feel tons of heat coming from there.
bigjohnson4.6gt
i keep my ipod in that filp up cigarette lid, and when i pop it open after driving long distances, or anywhere on a hot day theres a burst of hot air coming from the transmission, pretty sure its pretty normal
94Vert
yeah i've had that too, normally if i drive for an extended period.
94Vert
when i put my new shifter on i had to modify the boot but not by much. there's just a little space showing
scarface
I do too, but I only get hot air into the car if I crack the windows and create a vacuum inside the car.
WyoTechMSA
I notice this on my dads 98 vert, but I honestly have never noticed any heat around the center console/shifter area in my car. Guess Im just lucky.
TxCobrA98
my tranny gets hot after a while too..
but i can definitely feel heat from my feet. pretty sure its the heat coming off the exhaust though.
ripper
Yea I think its normal mine gets hot too. When im waitin in line at the track I gotta run the AC it gets so hot in there.
Foster98GT
Same here, it gets crazy hot in both of my cars...When i redo the carpet in the Fox, im gonna try and find something to reduce interior heat...
Schiffy
Norfolk, Va
Mine too... but i don't have an inner shift boot, and my leather shift boot is ripped around the bottom, so i get a ton of heat coming in through there... if i can ever get up to the junkyard, i'm goring to grab a new inner, and leather shift boot, see how that works... I just assumed it was normal, and the reason mine was so bad, was because of those two issues i mentioned above.
Passenger
Dynamat would be a good solution here. It prevents heat, and would make it a little more quiet inside the car.
96GTPlanB
