heat
Orange 94
Alberta Canada
I assume yours is manual? Mine does the same. What slykin said makes sense for mine, my lower boot is in poor condition. I don't think there's anything wrong though.
mine use to be the same, seemes like I noticed it more after the x-pipe and side exhaust I put on. It was bad enough on mine that after long trips you could feel the consol radiating heat. I replaced the shifter gasket and then when I replaced the carpet I installed 2 layers of heat sheilding material(thermal block by second skin) and its been cool sailing since.
1997GT4.6
I have the same issue. Doesn't bother me though and its not all hot every time I drive it. My GT did the same thing. Its weird but don't have the will do anything about it lol.
Burninrock24
Minneapolis, MN
It's just a trade off of a cheap performance car. If you want a hot driveline go ride around in a viper all day. You will be able to cook eggs off of the center console and footwell.
OxmanWI
Milwaukee, WI
If your shifter is heating up so that it's hot to the touch I would look at the transmission. When was the last time you had a flush or replaced the filter? Do you have a good cooler in place? Do you have a trans oil temp gauge hooked up? Sounds like a overheating issue to me, but more info should be posted.
