HELP ASAP WITH TRANNY!!!
SURGEY POOH!!!
HI!!! ok i have a automatic 95 mustang gt 5.0 and when i first start it and then put it in drive it feels like the tranny grabs for a while and once i press the gas and it slips and gives out and just revs and wont move any more i put it in R wont moove put it in 1 or 2 nothing feels like it stuck in neutral please help thank you
LAFENATU
SURGEY POOH!!! said:
LAFENATU said:
What color is the fluid? Does it smell burnt??
it looks like clear/red it doesnt smell burnt it smells nasty tho
My guess is it is probably time for an overhaul. How many miles are on the trans?
LAFENATU
noooooOOOO...... 117xxx miles :(
Yeah, she's probably tired. It might be something simple but it not wanting to engage in any gear is a problem..
SURGEY POOH!!!
is it easy enough to do it yourself or no ? because i dont have alot of money im a college student so any suggestion? i cant even get it out my driveway
LAFENATU
I wouldn't even come close to touching an automatic.
Search around for used AODE's...craigslist, corral.net, Stangnet etc.
Lee12609
www.car-parts.comhttp://
but i doubt it needs a rebuild if it hasnt had any symptoms until now.
could be something simple. do you see any leaks around the transmission? you dont sound sure that the fluid level is good. if your driveway is on a grade and its low on fluid it will do this. most of the time the pump doesnt just go suddenly like that.
LAFENATU
Lee12609 said:
www.car-parts.comhttp://http://http://
My AODE's front band went bad, the day before the car drove perfect. Just like someone flipped a light switch..
Sometimes it can happen.
SURGEY POOH!!!
Lee12609 said:
www.car-parts.comhttp://http://http://http://http://http://http://
no my driveway is flat .. it was fine yesterday and then it started acting up it felt like it didnt want to shirt into 2 so i had to gun it until it would shift into 3rd and then i stopped at a light and the i press the gass and it wouldnt go it just rev but not when i start it and put it into drive i let go of the brake itll go but when i press the gass itll rev and wont move and when i turn it off and start it again it will do the same thing again
Win
Kennesaw, Ga
Not necessarily the AODE i had in my old 95 Vert went south at only 57k miles on it.
Lee12609
i wasnt talking about mileage, i was talking about symptoms. he made it sound like he just went out there and all of a sudden it wouldnt move, which almost NEVER happens with an AODE/4r70w..... not saying it doesnt, but its very very rare. usually all of them will exhibit some sign of problems before needing a rebuild, and even then alot of times its heat related, or a control problem and not the actual hard parts that failed. problem is most people dont know crap about transmissions and think since there is a problem it needs rebuild, and transmissions shops will tell you it needs rebuilt pretty much no matter what.
my car has 200k miles on it, pushing 10+psi, never had a cooler, and the pan was never dropped. it started flaring badly, and didnt want to shift right, very inconsistent and my torque converter clutch was cutting in and out. everybody in person (including shops) and online told me it was time for a rebuild. against advice i dropped the pan, changed the filter, drained the torque converter and refilled with mercon V, and added a cooler, and i've never driven a 94-97 that shifted better. the 98+ have a different valvebody so i wont include them, they all shift great.
Win
Kennesaw, Ga
Lee12609 said:
Win said:
Lee12609 said:
www.car-parts.comhttp://http://http://http://http://http://http://http://http://http://
I guess i was a rare occasion then. I drove it to work and it started shifting hard then the next thing you know it won't go out of 2nd gear. Had to even manually shift it to get it to do that. This is with a full service record of every 12k miles with a new filter and fluid.
