Help - front brake disc removal
sparky
Port Orchard, WA
Hey guys. I am installing new struts/springs up front. I removed the calipers and anchor plate, but can not seem to remove the disc. Am I missing somthing? Any tips?
Tony
ohio
mine were a ***** to get off too, lol! i got pissed and beat the hell outta them :)
Tally_4.6
More well known than you
Clermont, Fl
PB blaster...wait 5-10 minutes...hit with hammer multiple times. If they don't come off, repeat process.
SRT Handz
I use this method. Works EVER time. even on the most stuck rotors.
[video=youtube;mtsTJCRljAs]http://www.youtube.com/watch?v=mtsTJCRljAs[/video]
98Warhorse
Pharr, TX.
Very helpful, i'll be doing this soon aswell, i picked up a set of cross drilled and slotted rotors cheap that i want to install.
take down the date and time ladies and gents. handz just posted actual tech.
congratz, Greg. lol.
also, if you use that technique (first time i've seen it, as well) I suggest putting anti-seize on the bolts to ensure those nuts dont lock onto them and you go from a frozen rotor to a frozen rotor+frozen bolts. lol.
vermilion
maryland
also using a heavy harden rubber mallet adds shocks without gauling. in a criss-cross pattern, hit it really good. while you are there, replace the front bearing hub.
:golf claps: for handz. it only took almost 13k post to actually post tech.
SRT Handz
I post plenty of actual tech.... non of you guys actually take the time to read any of it.
