*HELP* Fuel Line Removal @ Tank on 94 GT
CNTLOSE
I am trying to disconnect the two fuel lines at the tank so I can remove the pump. I have tried using the white C clips you normally use on the foxes and on the fuel rail at the motor, but they are not working at the tank...and I have broke one trying.
Is their a special tool needed on the 94/95 fuel lines at the tank? Or am I just not getting it with the white C clips? :confused1:
Thanks for any help.
Win
Kennesaw, Ga
I have used the Clips and also the Metal line removing tools i have. You need to push the line onto the neck more then while it is on there then slide in your clip making sure that you don't slide it back off. There are 4 clips you have to depress.
C
CNTLOSE
Got them off thanks! Just put a little more effort into knowing it was the right way...did not want to break them before.
