Help picking some things out
ThA SkInNy
I've been collecting parts for a little while now and I and getting ready to put the newer motor and trans in my 95. While I am pulling it I am going to add the parts I have and have been collecting over the last few months. Is not much but should make the car fun!
Here's a list of what will be going on:
Stock bottom end and cam 5.0
Gt40p heads (looking into roller rockers just not sure of ratio)
Gt40 explorer intake
Trick flow elbow
Trick flow under drive pulleys
Mac shorty p headers
BBK stainless O/R x pipe
MSD 6al ignition setup
Sub frame connectors
Centerforce HDX
Steeda cable and quadrant
4:10's
For exhaust I have 2 options I have a set of super 44's and a set of stainless works race mufflers from a gt500 kit. Regaurdless It will be a dumped exhaust system. I'm just not sure which ones to go with.
What compression ration can i expect with the P heads and I'm also kinda wondering what kind of power I might expect to see ...lol Any ideas or input at all is appreciated.
http://www.flickr.com/photos/43445913@N03/7674104744/
http://www.flickr.com/photos/43445913@N03/7674106062/
I posted in the intro section and had some tech questions so I just copied and pasted... Lol
I'm wanting to know what is the recommended spring to use for the setup I'm putting together... I definetaly want it to rev but I'm not sure if I'm going roller rocker orcnotvjust yet.
Any help is greatly appreciated!
Thanks
ivan12
Sounds like you have a good set of parts put together, I'd personally wouldn't install the under drive pulleys or the steeda cable, stick with new OEM.
ThA SkInNy
ThA SkInNy
Why not may I ask? Ivecheardcthecsteeda cable can be weak at times with a heavy clutch.
ivan12
most adjustable clutch cables fail prematurely. As far as pulleys, unless you put on an overdrive alternator pulley you will most likely have charging issues.
white95
Apex Junky
Admin
Prairieville, LA
I also wouldnt go for the underdrive pullies, theyre more hassle than worth. Also, Ive had an adjustable cable and Steeda double hook quadrant for years with no issues. I guess I'm lucky?
I would run 1.7 ratio roller rockers with the stock cam and stock pistons. You should consider a Trick Flow Specialties stage 1 cam, a set of hardened pushrods and 1.6 ratio rockers. That would help in the "rev" department, give you a modest power boost and make your pony sound mean :) Consider a Moates Quarterhorse chip!! It will help at dyno time, I think I have an extra one.
Exhaust.... The great debate!! IMO stay away from the Flowdisasters but if you want a chambered muffler, run MAC... The GT500 mufflers are intriguing otherwise I'd go with Magnaflow, SLP or Vibrant. Mainly depends on what your exhaust note taste is.
I would anticipate 275-285 (+/- 10) rwhp with the mods you have listed. I made 243 with next to no mods when I had my 5.0!!
ThA SkInNy
ThA SkInNy
^ thanks for the info! Much appreciated! What do you want for the moates chip? Most around here tune on sct...
white95
Apex Junky
Admin
Prairieville, LA
I need to look for it. In the event i cant find it, if you are interested, Greg Moates is a vender on here and actually lives in my area :)
RichV
CO
I run the UDPs and adj cable, no issues. But I don't run any electrical stuff except motor related.
My GT40P heads have the trick flow springs, do not have a part # tho. I didn't install them, I want to say they are the springs matched to the stage 1 cam. I run a E303 cam, pulls just fine in the higher RPM.
zepher0n
Williamsburg, VA
About the adjustable cable: I installed one with my HDX clutch about... 8months ago. I have to crawl under the car every month or so to readjust that ***** at the fork. Exhaust.. with your O/R pipe, I think you'd be happy with pretty much anything, haha. My father had super 44s and they sounded great. I went with an SLP loudmouth catback and Pypes o/r pipe and holy crap, is it loud and mean, sounds awesome.
ThA SkInNy
ThA SkInNy
Thanks for the replies guys!
What valve springs should I go with for gt40p heads?
