HELP PLEASE. Cold Start Problems.
Fender1325
Guys this is driving me nuts and I have to leave a half hour early if I want to be on time to work.
Whenever I start my car up after its been sitting over night the electronic choke wont do its job and itll die. I have to keep my foot on the gas and keep it at 2K for a bare minimum of 10-15 minutes just to get her idling on its own. Then once i start driving and change gears, whenever i push the clutch in it jumps down to about 600 rpms real fast between shifts. Once it gets a good warm up it runs like a top.
I have cleaned the throttle body and IAC.
What do I need to do and whats it gonna cost. I'm broke as hell and need this pain in the ass fixed. Thanks!
GDTrumbo
Nashville, TN
Kinda unusual symptom. Like the choke circuit is disfunctional. I want to say check for vacuum leaks but... Did you remove the TB from the car when you cleaned it? IAC gasket damaged somehow??
Do the battery disconnect/ECM re-calibrate thing to it. Still persist?
GT
NORTON98
When I had starting problems and weird idle issues I found that I needed a new fuel pump...
