hottwheels04
- Joined
- Jul 14, 2006
- Messages
- 2,150
- Reaction score
- 14
I'm Having a few new problems I wanted to see if some guys could help me out.
1. I have been having intermitate charging, overheating issues, I think my alternator is going on its way out, I notice when I first start my car, the temp gauge and gauge reads fine around 12-14 normal volts, but once i starting driving the gauge shows around 10-11 volts, and if i rev it and turn on the radio etc, the car starts to show overheating and the gauges will dim a little. so does it sound like a weak alternator?
2. I never had this problem before, but last night I went to park my car and when i turn the wheel i felt grinding and was hard to turn the wheel was makeing alot of noise and bad feedback so i got out and saw discoloration on my headers and the sterring shaft was spinning near the back tube and rubbing on the header, whats weird it only did it one time and hasnt done it since, I assume because metal expands when hot the header tube gets hot it rubs? How can i fix this problem, a new sterring shaft? should I be worried it will ****ing up my need ceramic headers?, it pisses me off cause i just put my new long tubes on and now its all discolored like whitish near the back tube where the steering shaft hit the header tube.
3.I have aftermarket head unit and speakers, 6'9's, my ? is can i run factory rear mach460 amps on aftermarket tweeters? and how, i notice a grey square plug hanging from rear aftermarket speakers, do i just plug in the amps to that and somehow bolt the little amps in the back? is that it? i bought my car with the way it is alreayd had aftermarket , tweeters/ 6'9's and aftermarket head unit, I just put a new head unit in and i want to put in amps for back speakers, I dont to spend $ and buy component speakers or subs or aftermarket amps, I can pick up some factory 460 rear amps.
