Had it scanned at Autozone- came up with
P-1151 and it says " ECM could not adjust fuel trim because of a lean or rich condition. probable causes Fuel pressure too high or low. MAF sensor defective or dirty, Vacuum leak, leaking fuel injector or FPR.
P-1131 - lack of bank 1 02 transistions -lean explanation ECM detected bank 1 02 at its lean limit. probable causes : misfire bank 1,vacuum leak, fuel injector bank 1 only.
And then it had 2 more codes for 02 sensors..
Since the car recently blew a head gasket, the man at autozone said that the Cat convertors was probably stopped up and thats whats causing all of this. What do you guys think?
