help with fuel injector size ???
xs man 27
i have a 95 gt that came with a few bolt on when i purchased it, i currently just upgraded the cylinder heads to trick flow twisted wedge 170cc heads, comp cam xtreme energy 270xe camshaft, comp cam ultra gold 1.6 RR's, comp cam lifters, comp cam hi tech push rods. comp cam timing chain. i also have edelbrock performer 2 intake, bbk c/a/i, throttle body, 24 lb injectors, 190 lph pump, underdrive pulleys, bbk long tube headers, bbk o/r h pipe, flowmaster exhaust. my question is can i use the 24 lb injectors in there now or should i get bigger size ones ? after i have my engine all wrapped up i m going put 3.73 gears in and than go get it tuned. when i go to get it tuned i wanna make sure i have the right injectors in there and dunno the size i should be using .. thank you all for any info .. take care
X
xs man 27
sounds good guys.. thank you for all your info.. hopefully the ones in there now are in good condition and don't need replacing..
If you plan on doing a bigger engine soon might aswell do 30#
But as previously mentioned above 24's should be fine
