help with wires!!!!
ellerstang
Kingsville, Tx. 78363
In the past I was running 12.6's on my 5.0 swap from the v6 and then i was planning on dropping a 351 with a turbo setup on it.
but that has all changed when i came across a deal i couldnt pass up. well check out the pics first.
as you can see i managed to put the 05 4.6 in my sn95, now my real problem is trying to deal with the wiring i pulled the intire wiring from the 05 and droped it in my. my question is does anybody know the color coding to the wires to the door panels and to the steering column so i can set it up and when done ill send a video to the lounge just waiting on more income still have to get manual brake installed get the bellhousing so i can put my c4 behind this and then soon some upgrades once i get it running right. thinking about a super charger, not sure yet.
if anyone can help i would greatly appreciate it.
Grnstang
Wow!!!! That is friggin awesome man! I have no idea about the wiring problem, but I hope you figure it out. That'll definately be a unique sn95 when it's done. Good luck man!
duff daddy
you need to get riends at ford. i dontk now how their systems are set up but ALOT of cars went to bus circuits in 05 ish. you need to get your hands on a service and powertrain manual and you may stand a chance. there is gonna be so much to swap BUT wiht the whole car and the WHOLE 05 wiring harness you MAY beable to do it
