Help
BruhBrahBrad
Ok I have a few questions. How do you remove the nostrils from the stock gt hood?
How do remove the emblems and will stock 5.0 emblems fit where the gt is?
Has anyone used like pin striping tape around the lip of their rim? if so how does it work?
How can I tell what gear ratio I have if not stock?
Im sure theres something else but I cant think of it :BangHead:
Thanks
B
BruhBrahBrad
Oh Now I remember!! My passenger side windshield squirter doesnt work what could this be ?
GDawg
To remove the nostrils, look under the hood and there are a couple small nuts that you remove for each one.
CC'S95GT
Hampton ,Ga.
if the driver squirter works the you probably have a clog at the nozzle itself, pull off the hose and blow air backwards into the clogged nozzle and hopefully that will clear it out.
CC'S95GT
Hampton ,Ga.
i just went out to and look and it looks like you need to take the panel off at the top of the firewall and you should be able to access the hoses from there. you may need to remove the strut tower brace to remove the panel too,just don't drive the car with the brace removed or it will be a pain to put it back on
B
BruhBrahBrad
OK now sorry for all the nooby questions but how do i go about taking that off? Its just that when I dont know how to do something my young mind gets frustrated then stuff can get broken :BangHead:
Adeptus923
