here's a new one..
1quk50
my car is full bolt on guys.. with stock ignition... i have a miss at high rpms.
anyone know what it could be?
i keep smelling gas in the car but i think it may be from th h-pipe. but idk..
Yes smell could be from H-pipe most likely. Check or replace your coil if it's old. I had my coil go bad and caused this problem and/or your ignition module can be the problem(on the inner fender wall passenger side under the stock filter housing). They go bad sometimes. I changed those two when i had the ignition problem.
BUT i checked every where for the problems such as burned or cracked spark plug wires etc etc.
Good luck man :)
1quk50
yea.. wonder were that line is located from what he says he cant find it either..
It is located inside the passenger side fender. i smell fuel after my x-pipe install. Mine is off road also, so i steer towards more to H-pipe. But it could be your lines. check to see. :thumb:
94GTcobra
I had the same problem with the gas smell i found out it was the gas cap, pretty sure thats what it is.
1quk50
did you just replace it? could it be the filler neck gasket?
