Ok FIRST OFF....
94-95 cars DO NOT SET TPS EVERY TIME ON START UP. I don't know who started that vicious fucking lie but it is bunk. I've talked PERSONALLY to numerous tuners about the sensitivity of the 94-95 computer. That is crap. Your car may run just fine with 1.08v at closed throttle but that doesn't mean its optimal. Even if it DID set the TPS everytime, that still isn't going to fix a shitty driving car is the TPS itself is just plain shot. CHECK THE VOLTAGE and set it as stated above. As for the MAF. Clean the wires. Yeah a C&L is a bunk way of calibrating a MAF in my eyes but they CAN work. The biggest problem with them is they are sensitive to turbulence creating false readings. Try clocking (rotating) the maf housing it self. Do like 90 degrees at a time. Sounds dumb but I've see it work miracles on some cars. The reason you car is doing it at part throttle only and not WOT is b/c at WOT your car goes into OPEN loop mode....i.e. it runs off of a set table for just that....WOT runs. The same is true for cold start ups. Basically, the car ignores all sensors during this. CLOSED loop is part throttle. Its reading from the MAF, o2s, IAT, TPS, and Engine Temp...so it can be a combination of those causing your problems. You didn't say if the CEL was on or not. Start with what I said there and then get back to us.
