HID question
DFG_magic
Kennesaw, GA
Sometimes when I turn on my headlamps, my ABS Light will come on and stay on. Do I need an HID relay harness that wires directly to the battery or is there another fix? Thanks in advance.
DFG_magic
DFG_magic
Kennesaw, GA
a generic 9007 VIP HID kit. 3 pc per side kit. (ballast, small box (i'm assuming the starter) and the HID bulb)
holy shit, where's the ABS module? Ever since I installed my HID fog lights when i turn them on it throws the ABS light, but if they're on when i start the car the light doesn't come on. It seems totally bizarre but it sounds like you might have the solution...
DFG_magic
DFG_magic
Kennesaw, GA
It's right by the fuse box. At least the test module and supporting wiring is. I had my ballast tucked between the inner fender and the battery. NO GOOD. Too close to the ABS circuitry. I moved everything right behind the headlight door and all is well. Even tested them out this morning numerous times on the road. The little red box right in front of the underhood fuse box is the ABS test unit. Drivers side of the car. These HID's are only 35w, but i'm guessing the digital circuitry on them is just powerful enough to cause interference with other on-board systems if mounted too close.
DFG_magic
DFG_magic
Kennesaw, GA
No prob. It's cake man. Lemme know! Maybe I can leave with the hood? :icon_rr: U picked ur new one up yet?
Suspect
ATL
haha. im sure it is, just sucks w/ no garage and its freaking raining nonstop.
no the guys coming to get on sat. so i hope to order it next week sometime.
hmmm i don't think my HID stuff is anywhere near that, I'll have to double check. Has to bet he same problem though I mean really.
96dkgreengt
i have the same problem. just installed my fog light hids only so far since they sent me the wrong headlights, and my fog lights were turning on my abs light..ima have to check how far my ballast if from my abs module
DFG_magic
DFG_magic
Kennesaw, GA
Guys, try to mount your ballasts and all wiring as close to the headlight housing or fog light housing as possible. Just make sure the ballast isn't too close to any computer controlled component under your hood. Since i've relocated my ballasts, all has been well with the ABS light malfunction. :knockonwood:
greenscobie86
The Big Apple
I've got the same problem.
My ballasts are mounted under the bumper between the rebar and the header panel, theyre hanging off the part that attaches the fender to the rad support(its a small bar.)
Since the ballasts are nowhere near the ABS test connector I am a bit confuzzled...
Maybe I have a bad ground somewhere but I doubt it, since my problem is identical to eveyrone else who has posted in this thread...
greenscobie86
The Big Apple
It might be^...
I remember mine not kicking on when it is wet out... I'm thinking maybe its a bad ground or something...
I grounded my Hi/LO leads(supplied iwth the VVME Harness) to the rad support with a whole bunch of factory grounds.
One of my ballasts went out recently, so I had to take the HID's out until a new one arrives. I miss my HID's :(.
Staff online
