Highlighted posts from Monday, Feb. 07, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
February 06, 2022 * 26 posts * 193 views
CobraEd said: That is part of the air injection system which hooks up to the smog pump. It is tied into a tube which crosses over between the backs of the two cylinder heads. Since you have ... Read more >>
February 06, 2022 * 18 posts * 56 views
J_lope82 said: This morning I went to remove the axle bearings because they were making noise. I pulled the passenger side axle and noticed the bearing starting to wear into the axle. Now my ... Read more >>
February 06, 2022 * 9 posts * 36 views
94StewFord said: The C-Clip that retains each hadlight won't budge! I can wiggle it back and forth, but she won't come off! Any suggestions? Tight space, hard to get anything on it and I see video's ... Read more >>
February 06, 2022 * 6 posts * 47 views
CobraEd said: First gear on the original factory WC T5 in my 85 GT also was 3.35:1. That was the first gear ratio in all of the T5s for 302W fox body Mustangs. Some of the other fox Mustangs ... Read more >>
February 06, 2022 * 1 post * 13 views
SN95Newsletter said: Click here to view on the web Highlighted posts What the Sam Hill is this?? February 05, 2022 * 22 posts * 89 views 94-95 5.0 - Specific How do I know what 1st gear ratio I have? ... Read more >>
Continue reading...
