SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
September 03, 2021 * 10 posts * 43 views
dookiemane said: Hey guys I've been slowly making progress on putting my engine back together. I've been trying to find replacement hardware for the exhaust manifold since the old bolts have seen ... Read more >>
September 04, 2021 * 3 posts * 28 views
07GtS197 said: Check the connector to the abs module. That era is known for its flaky Bosch abs pumps. I had one go out in my 02 Gt. I forget if I checked codes or not but the abs and traction ... Read more >>
September 04, 2021 * 1 post * 6 views
SN95Newsletter said: Click here to view on the web Highlighted posts Does this belt need replacing? September 03, 2021 * 76 posts * 596 views 94-95 5.0 - Specific September POTM - VenomPower September ... Read more >>
September 03, 2021 * 17 posts * 233 views
Monday said: Gas Cap. Fuel Filler Neck Grommet. Fuel Vapour Valve Grommet. I can't say this enough to anyone - Clamp the crap outta your car. It's a compressor. Leaks and Compressors are not ... Read more >>
September 03, 2021 * 55 posts * 621 views
Venompower said: Honestly the water... the wiring was more a maintenance issue in my mind. The connector kept the wires separated and the wire that had the worst rub through wasn't even used as ... Read more >>
Continue reading...
