Highlighted posts from Thursday, Mar. 10, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
March 09, 2022 * 13 posts * 134 views
BHernandez said: Can't tell where it's coming from. I'm usually inside the car when it happens and it's gone so quick, there's no real time to hunt it down. The timing chains, tensioners and guides ... Read more >>
March 09, 2022 * 10 posts * 57 views
ttocs said: the flasher uses the resistance of the bulb to determine how long if flashes. When the bulb is burned out, or there is a bad connection it will stop working. They are simple enough ... Read more >>
March 10, 2022 * 23 posts * 313 views
RAU03MACH said: It also is in your timing the more advanced The idle pickes up Check your throttle body , the shaft on the butterfly On the linkage end make sure its not bent forward against the ... Read more >>
March 10, 2022 * 3 posts * 21 views
jfisher said: New guy to the forums here. I've had my 1998 Cobra for about a year now and figured I'd start a thread to help diagnose a couple issues and document the build. I flew to St. Louis ... Read more >>
March 10, 2022 * 1 post * 6 views
SN95Newsletter said: Click here to view on the web Highlighted posts Rattling engine noise on cold start March 08, 2022 * 10 posts * 68 views 96-04 - 2V Specific How do you adjust the idle? March 08, ... Read more >>
Continue reading...
