Highlighted posts from Tuesday, Sep. 28, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
September 28, 2021 * 19 posts * 111 views
Notthenow said: Hydraulic is butter soft, but requires a good system to be able to bleed and flush the hydraulic fluid to keep it crisp. When you said you were having issues after driving a bit, ... Read more >>
September 28, 2021 * 40 posts * 316 views
Hopelessly-Devoted said: OK, so here is what I came up with for the relays. The images are more for illustration than anything else. Just let me know if I got it right, close or way off base. [image] Read more >>
September 27, 2021 * 9 posts * 35 views
ttocs said: Its been a while since I ran the factory o2s but your o2 connector should look like the link at the bottom. Looks like a 4 pin harness to me. The obd2 connector was only used with ... Read more >>
September 27, 2021 * 4 posts * 25 views
Daryl said: Speedometer and odometer haven't been working. Now the tach quit (even the mechanic tap no longer works). Did a new worm gear on speedometer . Didn't help. Question : where can ... Read more >>
September 27, 2021 * 1 post * 8 views
SN95Newsletter said: Click here to view on the web Highlighted posts t56 questions September 26, 2021 * 14 posts * 42 views General Tech Engine Drop Mounts September 26, 2021 * 8 posts * 54 views 96-04 ... Read more >>
September 28, 2021 * 12 posts * 188 views
TrickVert said: There's absolutely no reason to delete it (unless you have a wildly-blown or other radical setup) and good reason to keep it. Reinstall it the way Ford designed it, and install ... Read more >>
Continue reading...
