anyone ever bent the strut mounting plate? its definitely shaking like a bitch. the thing i hit was actually a big ass bump! had to of pushed the wheel way up into the well.EDIT- ^^ Beat me to it. lol Could have busted a belt in the tire.
Id pull the wheels off the front and take them to a shop and have them spin em on a balancer too. Ive had a bend so small you couldnt see it until it was spun at a high speed. But of course you could feel it like no other.
1 and a 1/2that would be all of 2 inches then right?
Sorry could not resist.
they look perfectly straight and i know its not the wheel cause i have 2 spares and replaced them both, still shaking like a m fr!I doubt it bent the strut, id check your Lower arm and tie rod end before you worry about the strut being bent.. +1 on balancing that rim just to make sure its not out of round..
hmmm steering shaft knuckle?? not sure what or where that is but i def wanna find that out!steering rack, tie rod, bent wheel, wheel counterbalance weight popped off, and steering shaft knuckle.
its pretty bad! the faster, the worse!Possibly knocked out of alignment as well which could cause it to pull/shutter a bit but not if its as bad as your claiming.
i have 2 spares from when i switched my rears to 10" wheels, i put those on and still fn shaking!Just my $.02, switch the front tires side to side and see if that changes anything? Might be a place to start?
