hit a bad bump and dam!!
Tony
ohio
as i was getting on the freeway i slammed into a big ass pot hole and now my fn front end is shaking like a m fr!! what should i look at fellas? any ideas?
Tony
Tony
ohio
first thing i thought of.....cant tell by looking but the only thing i can think of...???
Slykin
Tyler, Texas
Just jack her up and take a look under there. I'm sure if one of the tie rods is bent you'll be able to see it. If the wheel's bent you may be able to just spin it on the spindle and look for any "waves".
Saint
I had a bent inner tie rod once. You could clearly see the bend just by peeking under there.
Tony
Tony
ohio
well its not the wheel. i cannot figure this shit out!! :mad:
chris91
Cincinnati, OH
EDIT- ^^ Beat me to it. lol Could have busted a belt in the tire.
Id pull the wheels off the front and take them to a shop and have them spin em on a balancer too. Ive had a bend so small you couldnt see it until it was spun at a high speed. But of course you could feel it like no other.
Tony
Tony
ohio
anyone ever bent the strut mounting plate? its definitely shaking like a bitch. the thing i hit was actually a big ass bump! had to of pushed the wheel way up into the well.
silverv6
Florida
I doubt it bent the strut, id check your Lower arm and tie rod end before you worry about the strut being bent.. +1 on balancing that rim just to make sure its not out of round..
silverv6
Florida
Possibly knocked out of alignment as well which could cause it to pull/shutter a bit but not if its as bad as your claiming.
Goldmember
Cornwall, NY
Just my $.02, switch the front tires side to side and see if that changes anything? Might be a place to start?
Tony
Tony
ohio
they look perfectly straight and i know its not the wheel cause i have 2 spares and replaced them both, still shaking like a m fr!
steering rack, tie rod, bent wheel, wheel counterbalance weight popped off, and steering shaft knuckle.
hmmm steering shaft knuckle?? not sure what or where that is but i def wanna find that out!
its pretty bad! the faster, the worse!
i have 2 spares from when i switched my rears to 10" wheels, i put those on and still fn shaking!
