Hood Cleareance with Cobra Intake
bdbowti
Ok so i have been collecting parts for my 94 GT and just got a 94 Cobra intake this weekend. Now i am pretty sure the factory GT strut tower brace is not going to clear and i plan on getting the MM stb to replace it. My questions is will the stock GT hood clear the Cobra intake with a spacer? I will be running the spacer since i need to get taller valve covers to clear my pedestal mount Comp Cam roller rockers. Also does anyone know what valve covers will clear these rockers on AFR 165 heads? I have heard the stock ones may if you smack out the baffles but not sure. Just trying to get an idea of what kind of issues i am going to run into ahead of time.
Not sure how big those rockers are but the stock Cobra valve covers fit over 1.7 crane RR no problem and don't require a spacer for the cobra intake. Depending on spacer size i think it'll be close.
mic_lx
Well my stock strut tower brace did fit after the Cobra intake was installed... but I think my father had to bend it slightly on one side to clear the intake. The bend is not even noticeable and it doesn't feel any different.
95-stang
Having done this very thing, if you use a 1" spacer the Cobra intake will rub the insulation and the bracing underneath.
If you use a smaller spacer you will clear no worries.
RossA81
Monkton, MD
My gt40 tube intake hits the hood with a one inch spacer. It closes but it has rubbed a nice mark underneath the hood. Liner is removed.
Ross
96GTPlanB
