horsepower estimate
Knuckles281
Here is what I'm doing to my non-pi motor/car. Can you guys give me some estimate on how much power you think i'll have? What 1/4 mile times will I run?
PI head swap
Comp Cams #102300
O/R x pipe
C&L Intake Plenum
BBK 75mm TB
Cold Air Intake
MAYBE some head porting if I can stand to spend the money
For the driveline, I'm getting;
B&M Holeshot 2400 Stall
3.73 gears
Weight/Suspension;
Rear Seat Delete
Eibach Sportlines
QA1 K-member
Lower Control Arms
Battery Relocation to trunk
thanks guys
Knuckles@Empire
-Never Forget-
In front of you
if your putting cams in your car i think you might benefit from either getting shorty headers or a good set of longtubes. also if your going to be dragging your car alot you might want to think about the eibach drag launch kit. other than that your setup should be nice :thumb: make sure you get some sticky tires , i dont see why you couldnt turn a low 13 with these mods, anyway best of luck to yah :thumb:
p.s nice profile name :hammer: :thumb:
ck5.0
I didn't see it in the list but with the heads I guess I will assume you are doing a PI intake swap as well
black_96gt
Lose the Sportlines. Little or no weight transfer with a lowered car. Look into getting a custom stall converter. The price may go up but the results may be better. :thumb: Toss in some Strange or other adjustable strut/shock combo as well. Without cams installed and no port work I was able to hit mid to high 13's with 555R's and no diet for the car. I have my car modded close to yours, check the sig... Without getting specific, my car gained about 50-60 hp and almost 100 lb. ft. of torque, and those are real numbers, no guessing.
K
Knuckles281
I looked it up a few times, and asked on MF. Everywhere I checked it said that advertised stall was 1800-2000...
Jrgunn5150
My factory service manual say's the same thing.
