Why do I feel like this should be a straight forward, easy job? All I’m trying to do is disconnect the upper part of the front brake line. I put a 15mm on one side and a box end 7/16 on the other. Used opposing force to bust it loose. Wouldn’t budge. Tried turning clockwise in case it’s reverse threaded. Again, nothing.
It’s REALLY frustrating when what should be a relatively easy job turns into a PITA! :-(
Even hit it couple bursts of PB Blaster. Nothing. Bottom bolt 5/8” broke loose easy enough.
