MustangChris said:i suggest buying a set of OEM Black ones, if you can find them. paint and your time will offset the $20.00 cost of OEM used bezzles....
but if you do want to do them yourself...
open trunk
remove plastic pegs holding in far-rear plastic pannel on the inside
remove plastic pegs taht hold in all the card-board liners
remove liners (there are three of them total.)
remove the 6 nuts ( i think there are 6) that hold each tail light in.
slide the tail light housing forward
USE PAINTERS TAPE AND A SHARPIE TO LABEL EACH LIGHT BULB SO YOU DONT FORGET WHICH ONES GO WHERE
remove the light bults (twist and pull, they just lock in)
remove the three tiny screws holding the bezzles on (i think there are three)
unclip the bezzles and remove them from the housing.
paint (this includes sanding and priming)
install is reverse of removal.
MustangChris said:well im stupid. lol. i wrote on mine directly with a sharpy. lol!!
bottlefed97 said:MustangChris said:well im stupid. lol. i wrote on mine directly with a sharpy. lol!!
haha! At least you don't see em lol
