How do you pick a serpentine belt?
ivan12
My stock belt with full accessories fit perfect now that I installed my Procharger, the problem is I had to bypass my smog pump which is what ATI recommends. Since I'm keeping my smog equipment my plan is to get a longer belt to include the pump as well. I measured with a string and came up with 115 inches, but don't know if I should get the 115 belt or the 114.5 to compensate for the idler. Anyone do this before?
I just did this for my set up and a previous one as well, i've noticed the length you get with a string will never fit, you will probably have to add 1.5-2" over the string length. From what I've found if my memory serves there is no belt between 115 and 117', so I'd try the 117"
ivan12
ivan12
I just checked summit and all they have is 115 and 117.5 maybe that's why they ask to bypass the pump
Venom351R
Maine
Lots of trips to napa and buy multiple belts at a time. That's what I had to do when I removed the AC.
ProKiller
PA
yeah it sucks to find the right belt. i went the same route as Venom.
