How important to get C/C plates?
5.Woahhh
If I get sportlines how important will it be to get Camber, Caster plates? Even if I get an alignment afterwards.
ReplicaR
The whole idea of caster camber plates is to get your alignment correct after the car gets dropped. If you can get close to factory alignment with sportlines and with out using aftermarket caster camber plates, then you should not get it. Chances are though, it will be pretty tough to get the car close to factory specs w/o them.
Jrgunn5150
I didn't, and in about 20k miles, I literally wore the inside edges right off my tires. The outside was still great, so I mean, a tire is 200 bucks, I'd say c/c/ plates are a good investment.
5.Woahhh
Thanks guys. I knew it would be off somewhat after the drop. Hopefully I can pick some up cheap.
94Pro-5.0
Little Elm, TX
i have the pro-kit with no caster cambers. i do plan to get some soon, as i plan to do more suspension mods, but for now i have no problems not using them. my front tires are wearing pretty evenly.
if i had it in my funds right now i'd get them though
g_dogg
I had sportline witn no CC plates.
ruined my tires.
If you drop the car do it right and get CC plates.
Jrgunn5150
I thought mine were wearing evenly until the corner fell off. I'm not kidding, it wasn't the inside, it was the corner, the very edge next to the sidewall.
GreenPony95
I have some never used or installed upr cc plates if any one wants
100$ plus w.e shipping would be from point roberts w.a
pm if your interested
Magic
Some time zone
Sorry to hijack...
But should I get some C/C plates with the Eibach Pro Street Coil Over kit??
Jrgunn5150
I dunno what that lowers, but as a rule of thumb, anything more than 1.5" will throw the camber out far enough to be concerned about. I was at 2.10" lol.
vermilion
maryland
what is the ideal camber for lowered vehicles? my passenger side tire inner side wore out. :blah2: and i need new passenger balljoint.. "light bulb flickers"
Dalamar
SLC, UT
Magic said:
Sorry to hijack...
A B S O L U T E L Y!!
with a coil over, ALL the wieght is riding on the struts, into the tower, you need MM 4-bolt CC plates. :)
