How in the world do I......
BruhBrahBrad
how do i take off the brake calipers, im trying to paint them but i cant get the sumbitches off
bolts on the back of the caliper. mine were super tight too. or you could take the bracket off with the caliper attached
mich_666
those bolts are pretty stuborn... some sort of penetrant should be in order. make sure you dont contaminate your brake pads/ rotors! Obviously... lol
Hoseitdown
Matt94GT said:
I just painted mine on my last brakes and they looked okay, once there off without a caliper compressing tool its a PITA to get them back on.
I just used a C clamp...
cntchds
Just use a breaker bar and I think 12mm socket. It's stubborn, but it will work out.
topless95
but be careful not to break the bolt
best thing is sprat the bolts a couple times w/ pb blaster and then try a breaker bar or impact gun
Win
Kennesaw, Ga
Snakebit said:
Yeah if you have a little trouble just let Pb blaster soak for a little while.
topless95 said:
5.Woahhh said:
PB blaster will be your friend!
x100000000
Don't use a breaker bar unless it's the last resort. If your using a breaker bar that is 18-24" long you are putting close to 200ft lbs of force on that. You could very easily snap it right off. I would use a breaker bar as my last resort.
topless95
also you might want to spray w/ pb blaster wait, then tap the head w/ a hammer(do not pound it), then re-apply the pb blaster
greenscobie86
The Big Apple
PB Blaster and and Impact wrench did the trick with no sweat...
I gotta say... If it wasn't for PB Blaster I wouldn't have been able to take alot of things off my car haha...
