how much torque do 4.10s add??
rgs
none. no hp either.
your engine doesn't make any more or less power because of gears.
uncltrvlnmatt
Pa.
The engine make your H.P. and Torque. You actually lose H.P. and Torque in the trans, drive shaft, and rear. About 20% from the flywheel H.P. and Torque ratings.
justinschmidt1
They have nitrous or forced induction to go from the normal 300 ft lb to 4-500 ft lb.
Anyways, you should have 3.27s in the gear now so with 4.10s it will give you like .83 more multiplacation....
Basically you will multiply torque by 4.1 instead of 3.27.
I think thats like 20% more multiplying...should help you get up and go a lot better with that 4v.
Dalamar
SLC, UT
It's torque multiplication, like when you shift gears on your bicycle. your leg power is the same.
410's will feel great on any NA combo, you'll really like it.
Rice_slayer
Basically, gears give the "illusion" your car has more power without actually adding more. Example, Drive a stock Mustang like mine with the crappy 2.73s in the rear then drive a car, exactly the same, with say 3.73s. It will feel like the car with the higher gear(does it go higher or lower?) will accelerate better then the stock-geared car without adding tq/hp.
2slo95fiveoh
Lawrence, Kansas
the bigger the "number" the lower the gear, so 4.10 would be lower than 3.73 etc...
Fastfox400
I maybe be one of the crazy ones, but i like 4.30's an lower in a 4v. I have 4.10's now an its not enough for me. I'm considering 4.56's or maybe some 4.88's
96Kobrakid
so wat would be sum good torque adding mods and/or best mods n general without blowing all ur money?
96Kobrakid
also.....with my new gears n does it hurt me at all between 20-120mph?? as opposed to sum1 with a lower gear who will obviously have a better high end...im still ok top end between those speeds before it starts to hurt me rite??
realitygt
I've wondered that too... at what mph do 4.10's start to hinder your performance? and what mph for 3.73's?
