how to check transmission oil?
5.0kid
as title says, how do i check the amount on my 95 gt with a t5?
LAFENATU
Remove the fill plug and stick your pinky finger in..use it like a dipstick.
That is how I do it.
eliyarbrough
Nocona, TX
I've got an automatic, but they have to be in the same general spot! I had Lokar's added, but here's mine:
5.0kid
rio94 said:
there is a screw in plug on the side of the tranny.
ok, cool i'll check that once the snow is gone.
And i looked in my haynes manual and couldn't find anything about it.
95gtdrop
sacramento
Get under there with a 3/8 ratchet and extension. The plug has a square peg hole. The extension fits right in. There are two plugs one is a check and the lower is the drain. Be sure your on a flat surface.
Hoseitdown
pick the highest plug.lol
foss_94gt
ya for sure or ur going to get a messy surprise lol
427danderson
The T5 does not have a dipstick... you have to get under the car and stick your finger in the fill plug.. the correct level is right at the hole... when the car is level... The fill plug comes out with your standard 3/8" ratchet.
Good luck..
topless95
if you have never changed the fluid, or just bought the car and don't have documentation as to the last fluid change I would go ahead and change the fluid.
Use the top plug to check fluid/add fluid and the bottom plug is to drain the fluid.
I have found that when filling it is easiest to fill from inside the car, by removing the shifter boot and trans dust boot then feed a tube down and into the fill plug.
