HOW TO; gauges
94mustanggtfast
i have a wideband air/fuel guage and a boost guage i want to install this weekend. is there a how to on that or does anyone have any tips or tricks? there AEM brand
I have been waiting to get the bung welded on the exhaust to get mine wired up. Read your instructions as to how far away from the header it needs to be.
forcefedhatch
Pretty straight forward bro.. But i deleted my radio so all of my 30 bazillion gauges use the power and ignition sources from there.. Other than that the O2 needs to be I believe within 30" away from the header but is this an n/a car or?? Mines turbo but to a single exhaust downpipe that's where my o2 is located.. If its n/a I'm not sure cause it is a dual system..
Sent from my iPhone
forcefedhatch
Ok well set it up so that it will be an easy transition from n/a to F.I. ( exhaust routing etc..) think this through thoroughly trust me, you don't want to do this all over again for an already challenging build..
Sent from my iPhone
Venomized
Iowa
IIRC the wideband O2 can be put in either sides down pipe and get correct readings.
