how to tap head accessory bolts?
5.0kid
is there any way? i didn't think of checking them when i bought hte heads and two were drilled out without being tapped. I'm thinking i may just put some cold weld in there with the bolt and hope i don't have to take the bracket back off, but that is not so great of option. any suggestions? the hole doesn't go far enough to use a tap...
Paul
I'm not sure I understand what you're saying. You bought heads that aren't tapped for accessory holes? What heads are they?
They have holes, but no threads?
5.0kid
they have holes but no threads. it looks like the guy must have stripped the original ones and instead of using a bolt extractor he cut it down and drilled it out, but didn't put new threads. i've tried to tap it but the tap is too long.
Paul
Sounds like you'll need to heli-coil the heads. If you're not any good at this, I would suggest taking them to a machine shop.
5.0kid
wouldn't i need threads to use the helicoil? i'll call my machine shop tomorrow and see what they can do. It sucked, i had finally put the new head on when i found this out.
Paul
No. Heli-coils are inserted into drilled holes. The machine shop should be able to take care of you just fine. Don't forget to put anti-seize on your fasteners to prevent this from happening again. :)
P.S.I.cho
correction heli-coils are threaded into a hole, so yes u need threads, and i wouldnt use a heli-coil, a kingsert is a much stronger solution, the machine shop would be able to tap threads into, but the new hole may be larger then the original so a kingsert or heli-coil would need to be used to make the thread size smaller or a larger bolt would be required
5.0kid
ok, cool. sounds like i'll take it back to the machine shop on monday. i'm hoping that it won't cost too much since it would be minimal labor.
P.S.I.cho
you could drill the hole your self and tap it but the risk of drilling off center would be too high for me atleast id rather spend the little extra $ to get it done right
Jrgunn5150
It should cost you 20-30 bucks to have done. A pic would help, but I think the machine shop is the best choice :thumb:
