how wide can you go?
down shift
hi guys i got a question for ya. can you have a 17x9 wheel (95 cobra) up front and go lock to lock on steering without problems?
ReplicaR
Well, considering that at full lock the tires go right into the sway bar, there is not that much space. You just have to conciously remember not to steer at full lock.
I believe if you switch to 03 Cobra A arms you should be good to go, might depend on the tire though if you run 255's you might be okay. What was your plan?
Win
Kennesaw, Ga
i know my cobra rims are a 17x8 but i run a 255/45 on mine and have never run into a issue. I used to run 275/40 on stock tri bars and never had any issue unless it was a full full lock turn
ReplicaR
Take a look at your swaybar. Does it have some paint missing maybe, right around where the tires would be?
sbr420a
hell i dont know i know my 315 hit my quad shock or used to hit it
down shift
if i went with 17x9 i would probably run the widest tire i could so i probably want those 03 cobra A arms any idea where to find a set?
Steven
SC
275's up front, rubs at full lock. Stock control arms
315's out back. 2-3 inches of room.
SRT Handz
I run 275/40's up front.....I know they hit at full lock...but then again so did my 17x8 245's lol
down shift
i think i will stager the 98 cobras up front and put 95 cobras out back (only on track days) for more grip
SRT Handz
go 275's 1ith 17x9 up front..... it take alot of understand away from the car.
Paul
Just like Handz takes a lot of understand away from this forum. Handz, don't post tech advice when you have no idea what you're talking about and no personal experience.
Paul.
LAFENATU
Ford Racing 2003-2004 Cobra Front Lower Control Arms Kit
Part Number: M-3075-D $259.95
Description:
● This kit enables owners of 1994-2004 Mustangs to upgrade to 2003-2004 Cobra Mustang control arms.
● The kit features (2) front lower control arm assemblies with 50% stiffer rear bushings and low friction ball joints.
● These control arms have a redesigned stamping to improve the turning circle approximately 10% on 1994-1998 Mustangs.
http://www.summitracing.com/search/?keyword=M-3075-D&dds=1
LAFENATU
Paul said:
Dang. Those babies are pricey.
werd.
I was fortunate enough that my father put them on this car before I took posession of it.
