kennebellgt
- Joined
- Nov 15, 2008
- Messages
- 74
- Reaction score
- 0
I installed urethane motor and transmission mounts, I used to get this vibration at 70+ mph but now I am getting them at ALL speeds its pretty severe, If you were to have change on the dash it would be bouncing around thats how bad it is, So i jacked up the car and ran it with the rear wheels off the ground and noticed my driver side rim is bent pretty bad, and the passanger rear is bent also but barely, also my tires are not balanced, and one more thing i noticed my drive shaft has a wobble to it when the car is in drive and the wheels are off the ground spinning, i tried to move the drive shaft up and down side to side and i tried to spin it to see if there is any play in the u-joints and they wouldn't budge, so i dont think my u-joints are bad, I think maybe installing the mounts make it more noticeable that there is a problem, the car does this even when coasting with the engine off, so what im asking is whats your opinion on what could be wrong and why the drive shaft would wobble like it does under load, thanks guys
:sad5: :crybaby2:
:sad5: :crybaby2:
