GeeTeeFiveOh
So a while ago I needed to modify by MAC cold air intake tube to fit with my 93 cobra manifold and elbow adaptor. In the process I decided to remove the nipple that is supposed to have a vacuum line plumbed between it and the oil fill tube. I put after market valve covers on at the same time which had no provisions for this connection. DECIDED TO DELETE THIS VACUUM CONNECTION.
Recently I noticed the car making a horrible hissing sound after being shut off, the harder I drove the car the worse it hissed on shut down. I traced the sound to the passenger valve cover area and decided to start looking for new "permadry" valve cover gaskets since I used the crappy cork ones. After googling the shit out of hissing valve covers on shut down I found that my PCV system was not functioning as intended with that line plugged.
I had a nipple welded on the air intake tube between the MAF and TB and my new trickflow oil fill kit had provisions for a vacuum line on the fill tube so I made the connection the way its supposed to be. HISSING SOUND IS COMPLETELY GONE ON SHUT OFF.
How much damage have I done? I understand the way I had it setup before was not good for the bottom end seals at all.
