I need to stop this leak!!!
x182dan
Ok I need some ideas here on what to do. I am having a leak at the VSS on my T5. I have changed the stupid oring two times and it still leaks. It leaks enough to put a drop of tranny fluid on the ground every night. What should I do? I tried a bigger oring but when I did that it wouldn't push in the tranny at all so it wouldn't work.
Dan
CC'S95GT
Hampton ,Ga.
is there any crud in the hole where the VSS sits? Is the o-ring cut or rolled? Are you sure it's not the tail shaft seal?
X
x182dan
I know its the vss its leaking right on the crossmember and I had the tranny out for a clutch job.
