Iac mod
Adam Vinnicombe
Hi all I’ve just tried the IAC valve mod were you fit a gasket with a smaller hole to restrict the air flow to allow the rpm to drop faster. Now it has worked the rpm most definitely drops faster but my idle has increased from 850 to 1200 rpm what’s going on?
Anyone else done this mod and had the same problem?
lwarrior1016
Mr. Secondary Timing Chain
Staff member
South Mississippi
Kind of sounds like you might have a vacuum leak. Double check all your hoses that you’ve been messing with.
Staff online
