ignition problems
Willis_98GT
DFW Texas
ok so after my cam swap my car ran and pulled great for a while. then out of no where it started to develop a misfire. some people said that it might be foul plugs or bad wires.. but actually when i took my car in to get a sideways inspection done on it they ran off the codes and here they are
P0352 Ignition coil B Primary/secondary circuit malfunction[/b
P1443 Unknown trouble code
P0135 02 Sensor heater malfunction (Bank1, Sensor1)
P0136 02 Sensor circuit malfunction (Bank1, Sensor2)
P0141 02 Sensor Heater circuit malfunction (Bank1, Sensor2)
P0155 02 Sensor Heater circuit malfunction (Bank2 Sensor1)
P0156 02 Sensor circuit malfunction (bank 2, sensor 2)
P0161 02 Sensor Heater circuit malfunction (bank 2, sensor 2)
i could care less about all the 02 codes because its going to be tuned soon. but i found the first one to be intersting and is most likely the problem of my ignition troubles.
Jrgunn5150
Actual cam timing, however, you can swap the coil packs, and clear the code then see if the code jumps.
W
Willis_98GT
DFW Texas
comp 270s.
i just dont see how cam timing could be a issue since i drove it for 2-3weeks before this problem started
before that it pulled to red every time and never missed
W
Willis_98GT
DFW Texas
on the corral they said that it might have to do with the #2 cylinder wire also.
but im going to change the coils tonight with another set of stock ones and examine the #2 wire and possibally pull the plug too.
W
Willis_98GT
DFW Texas
forgive for double post.
but i put ngk tr-55s in it, oem wires, and oem coils. and it runs fine, and pulls hard once again.. man those plugs i pulled out were trash too.. very bad.
so im rockin it once again, trey you ready?
