Intake Gasket Help Now!! PLZZZ!!!
Corbic
Ok, I'm getting the 'stang back together, but I'm stuck.
I have an updated NPI intake with built in gaskets and aluminum cross flow.
Do I reuse the old cylinder head gasket???!? The plastic jig-saw looking thing with rubber seals built into it?!?1
Thanks! :thumb:
voidfinger
ok, does the intake have the built in rubber gaskets? if so then that doesn't need the intake to head gaskets. If it is just a solid plastic flange then you will need new gaskets. If it has the place where the rubber gaskets suppose to go but none of them are there then you got screwwed ... i got a revised one off of ebay a while back b/4 i went with pi intake and it had the built in ones.
C
Corbic
yeah, it has the built in rubber rings, so I can pitch the plastic inserts w/ rings from the old intake?
