Intake leaks
quickstang_1994
Cross Anchor, SC
Car started acting up alot backfiring, spitting and sputtering, hestitating. I noticed a leak when the car was dyno'd and the boost was coming out the back of the motor (along with coolant)
Q
quickstang_1994
Cross Anchor, SC
it wasnt smoking but looks like the oil and coolant was mixing then blowing out the back of the intake. but their is no mixing in the radiator, overflow, hoses, nor in the oil so.... maybe the boost was keeping them clean not sure
86svo9l
Cedar Rapids, IA
Keep those for your wall of fame. I am going to assume something else is going on, it seems suspect that it would happen to the gaskets around all the coolant passages. Good luck and hopefully its back on the road soon.
Spd0lit
SoCal
Also you should try the steel core felpros. They are much nicer and hold their shape really well.
Q
quickstang_1994
Cross Anchor, SC
it seem the gaskets are a race type gasket and they decompose after so long and they have been on since 03 so it was past time. and yes i am switching since i found that out
