Intake replacement and water pump size questions
Rocco_Roush
2002 Roush Stage 2
1. how do i know what size water pump i have?
summit has 4 water pumps, different lengths AND clockwise or counterclockwise. how do i know which one i need?
https://www.summitracing.com/search...motorcraft&SortBy=default&SortOrder=Ascending
2. prepping for the dorman intake (just realized, haven't had her long) wetting the bed. when i change to ford intake i will need intake gaskets, water pump (might as well) and anything else?
thanks!
SnakeBit!
Florida
Midway through the production run for the 2001 model year Ford changed the design of the water pump on the 4.6L engine. The older style pump produced from 1996 to mid 2001 had a longer shaft. In January of 2001 the design of the pump was changed to a shorter shaft.
Rocco_Roush
Rocco_Roush
oh perfect! so just get the longer of the two? do i need to worry about clockwise or counterclockwise? lol
is there something i can visually check before taking the water pump off so i know i buy the right one? thanks!
Benni614
Delaware
2002 Roush Stage 2
thanks!
Measure the length of the water pump, just to b sure
And why go dorman oem and not upgrade to the Intake
Rocco_Roush
Rocco_Roush
alright so i'll measure the water pump before i take it out
and no, i have the dorman on there (just got the car lol) so i would like the ford performance intake
Benni614
Delaware
Ford performance and dorman are the same FYI. I know people don't believe this but dorman makes the intake ford performance just stamps their name on it. I found this out awhile ago. Have u given thought into the edelbrock intake ?
Benni614
Delaware
PinkieT
Cleveland
Benni, I don't understand. Are you saying the Dorman intake for 4.6 PI heads is the same as the Ford Performance, or not?
Benni614
Delaware
I'm saying that dorman makes them and as for replacement I was just asking why go to the Ford performance and not nothing better is all
Benni614
Delaware
My apologies if I stated it wrong
PinkieT
Cleveland
So you agree Ford Performance PI intake (whoever makes it) is different, and better, than a Dorman from a parts store. The Eddy would be good for a blown motor like a Roush Stage 2 performance-wise but is taller than stock so would require their plenum to fit. They also recommend their own fuel rails. Only Rocco would know if it was worth the extra money.
Benni614
Delaware
Oh ok yeah I run the edlebrock and rails myself and love them honestly but yes its best for blown engines for max gains
SnakeBit!
Florida
if you read what I put up, you should have the shorter shaft pump.
EdgarR213
