The supercharger would have to have a straight outlet that could be rotated to point downward, which if this is for an sn95, it probably points backwards towards the throttle body. there is no way it will be able to squeeze an intercooler between the blower and the throttle body, as there is only a few inches there. If it had a straight out discharge, like a procharger, then you could plumb it down and around out front to get an interooler mounted then run it back up and around to the throttle body. Good luck with it.
